michellescott0557186
Here’s how to do the Delta ticket name change process the right way to avoid issues at the airport.
Call↭ (1)855 ⇌764 ⇌ 2734 ↭
1. Understand What’s Allowed – Delta allows minor name corrections only—like fixing typos, reversing first and last names, or updating after a legal name change (marriage/divorce). Full passenger swaps are not allowed.
2. Act Quickly – As soon as you notice the error, contact Delta. The earlier you request a correction, the easier it is to fix.
3. Call Delta Support – Speak directly with a Delta agent and explain the exact issue. Be clear and have your booking details ready.
4. Prepare Your ID – Your updated ticket must match your government-issued ID exactly. If it’s a legal name change, you might need to show proof (e.g., marriage certificate).
5. Confirm the Update – Once the correction is approved, you’ll receive an updated confirmation. Review it carefully.
6. Be Ready at Check-In – Show up early with the correct ID that matches your updated booking.
Mistakes happen—but Delta’s name correction policy makes it easy to fix small errors when you act fast.
Call↭ (1)855 ⇌764 ⇌ 2734 ↭.
